  #24
Old 04-21-2013, 05:48 PM
OilFieldMan OilFieldMan is offline
So it has finally warmed up to start doing some work on the Scepter. Who ever installed the new tank in 2008 left the rocor parker filter below a hatch that require the hatch to be removed and the hatch would have to be resealed with 3M 4000. Also in doing so they put a big kink in the fuel hose too.
I used the same route but re-located the fuel filter to the Port Aft Hatch. At the same time I re-located the oil tank to this side as well.
Original setup
Relocated routing. During this I also found that a couple of unions were used to make the hoses longer. Removed these and installed solid length fuel hose.
Also since it was warm enough I did the first layer of glass on the pad for the sea-cock.
Also a I need some more help from some scepter owners. If you look in the last picture you see the cheesy light duty plastic hose, I've changed the cheap and cheesy thru-hull to stainless and can't figure out how the heck to get to the back side of it to tighten the nut on the backside and install the new hose
1974 Seacraft 20' SF with 1985 Evinrude 150 VRO
1987 Seacraft 23' Scepter with 2007 250 HP Evinrude Etec
