Old 05-04-2013, 11:13 AM
ScottM ScottM is offline
Dieter Sprockets
Are you sure about that? Drill a hole through the side?
Yup. When I bought the boat, the previous owner had mounted 0 degree swivel rod holders in the gunwales and reinforced them by anchoring them to the hull sides. When I removed the rod holders, I was able to confirm the sides were solid glass. If you look in my photo, just below the rub rail 3-4 feet from the stern are 2 bolt heads about 12-14 inches apart. That is where the rod holders were anchored. I believe the coring ended around the chine/waterline area.
