Old 05-28-2013, 01:31 PM
Originally Posted by FossilMan View Post
I wasn't sure how many rollers would be adequate, but it seems like it has more than enough. Not sure if they pivot, though. I'm afraid this one might not be long enough, but I'll take a look to confirm. Thanks for the input.
I'm guessing that you've got a 23? If you divide the weight of the boat by the number of rollers, I think you'll find that the average load/roller is something like 100-150 lbs. I can wiggle the individual rollers with boat sitting on them, so I think that's an acceptably low level of load!
It looks like that trailer is an exact copy of an EZ Loader roller setup. The cross members are attached to a bracket that's bolted to the frame rail above the cross member and they pivot about that bolt. The pivoting rear cross member is important . . . when the CG of the boat gets aft of the cross member, it and the entire bank of rollers tilts. You'd better have a good brake on the winch at that point to keep it from screaming off the trailer! There is very little friction in that roller system!
