Simple and first question, is the shaft the bendix slides on well oiled/greased?
Don, yes i oiled that shaft two weeks ago I haven't tried grease yet, will try. Sometimes i hear a lot of back pressure from motor then starter disengages. I ran seafoam through the motor last week thought I had carbon build up but same results. Thanks.
http://s1103.photobucket.com/albums/...acraft%2020SF/ |
Clean all connections on the starting solenoid, starter and most important
the grounds!! This will cause more problems then most would think of.. Wire wheel, sand paper what ever you have make all the connections nice and shiney!! The old 2.0's are almost bullet proof! Keep us posted..
See ya, Ken © |
Bullet proof, I know it's still pushing my hull 38-40 MPH at full throttle, and the motor has never been apart. I just need to figure out this starting issue so I can shut her down while I'm drifting.
I had a similar problem with my starter did all the things mentioned but continued with the problem.
Finally I thought that I would have to get a new starter, so I said what's the worst that can happen if I take it apart. When apart I found what I want to say was a "carbon" like dust on the bottom part of the starter, cleaned it all out put starter back together and its been fine so far Hope it helps |
