Old 06-02-2013, 08:13 AM
Might want to also check and see if the transom angle is the same for some reason I seem to remember they are not the same.was looking at getting one from dusky before finding a stainless marine one for mine.have to say the guys at dusky were great to work with a family run business that cares for there customers
The angle will work just fine, checked that out before I got it. The sceptre has a angle of 13 degrees (some say 14 some say 13 mine measures 13). The dusky bracket has an angle of 12 degrees, more like 12.25 degrees so it will be close enough to use. The less than one degree will just let the swim platform have a slight angle down towards the motor. So small you wont notice and it will help the water run off the transom. I have read you can use a bracket at + or - a degree with no worries.
