Old 06-04-2013, 02:33 PM
After seeing Bigshrimpins bracket lift (floor jack adapter) I had to make me one. It will help a lot to have something adjustable under the bracket while test fitting it ect. I could not find a pipe or rod to fit the jack so I had to turn one down on the lathe. Once I got that done with that I welded it to a plate, drilled it so that I could screw it to the bottom of the jig I made yesterday. The jig is a small pallet with two bunk boards on the top for the bracket to rest on and the whole thing sits on the jacks arm in the same hole the cup uses.
