Mine will be mounted at around 4" up from the keel to keep the tub in the water as far down as I can so it will have maxim flotation and no drag on plane. The bolt on lip is facing outwards instead of inwards so 4" is the low as I could get it. Far as the motor mount, I haven't cut it down yet due to wanting to get it right. The bracket is a 24" set back and with a 25" motor I figured setting the mounting tab at 27.5" (2.5" higher for the set back). Everyone says a inch per foot of set back so that is 2 inches plus I will add a 1/2" to that and may need to go even more. Everyone also says they have to raise there motor up more so I may start at 28"-29" mounting height and them go from there. I will be easy to cut it down more but going up not so easy. What height do all you csc guys think I should set the motor at to start with for a 24" set back???? The help is appreciated.
Current SeaCraft projects: 68 27' SeaCraft Race boat 71 20' SeaCraft CC sf 73 23' SeaCraft CC sf 74 20' SeaCraft Sceptre 74 20' SeaCraft CC sf Last edited by flyingfrizzle; 06-06-2013 at 07:27 AM. |
