first,the blasting process was way aggressive second,the boat had damage /blisters under the antifouling pant after a hull is blasted,it will require a light "finish sand" to remove any residual paint.the hull will have a slight pofile,from the blasting -similar to "orange peel" being "in the business,as I am,i've lost count of the boats I've had blasted using both baking soda standard blasting sand,no damage on ANY boat.in some cases,the boats blasted,the water line was adjusted - the existing gel coat was sanded,wet sanded and compounded,to bring back the original finish... there's 2 subjects,these are the most MISINFORMED,full of "old wive's tales" subjects ever these subjects are "BOTTOM PAINT BLASTING/REMOVAL" and ETHANOL
