  #41
Old 10-06-2013, 01:58 PM
PharmD2B31 PharmD2B31 is offline
Don't forget to add in Dad's time as well...no cheating here on CSC
LOL.....This is true!! Maybe add in an additional 5 hours for my dads time. He just likes to get out and piddle with me on occasion.
Strick,
Didnt you rebuild a yellow 20' Seacraft??? I have been searching ClassicSeacraft high and low trying to find that build thread for that boat for ideas......
Old 10-06-2013, 04:31 PM
Originally Posted by PharmD2B31 View Post
... I have been searching ClassicSeacraft high and low trying to find that build thread for that boat for ideas......
Um. It's a sticky. The first thread on the Repairs and Mods forum. "Here we go again"
Blue Heron Boat Works
Old 10-06-2013, 06:53 PM
Oh wow!!! How in the hell did I miss that???? Thanks for the info.
Old 10-08-2013, 08:45 PM
Slowly pecking away at it.... Cut open the box stringers and removed all of the old foam. Also removed the fuel tank and the floor piece that the fuel tank sat on. I'm curious to know who had fiberglassed that piece in as it was 1/4" ply that had one layer of glass on the top side. The underside was raw rotten wood.
Old 10-08-2013, 10:40 PM
bilgerat bilgerat is offline
looking good!!!, your way ahead of Me on your 20 as far as progress on the tear down go's , mine looks to be in the same shape as yours,totally rotten, I did get my aft deck n splashwell cut out and the rotten transom wood dug out yesterday.
Old 10-09-2013, 12:55 AM
I've cut open a few of them and that's how they came from the factory. Top side of the wood was glassed but the underside was not. I still think your boat is factory judging from the amount transom rot, placement of "Potter Putty" on the stringers and the looks of the foam etc... I would not put it past the factory to use 2x4's imbedded in the foam along the perimeter for extra support.... BUT I've been wrong before
Old 10-09-2013, 09:00 AM
Strick.... I think you are right. All factory. And yes, there were 2x4s embedded into the perimeter of the boat down into the foam. There were wood screws screwed inside those perimeter pieces also.
Old 10-09-2013, 09:17 AM
Strick..... I was originally thinking that I was wanting to use Coosa for the transom and Divinycell for the floors, but after combing through your 20' build thread, I'm thinking about going back original with marine grade plywood.
Your thoughts??
Old 10-09-2013, 10:33 AM
I would say if you got plenty of money and are worried about weight on the boat I would go with the composites you spoke of, but if your not worried about weight much and just want it to last till you part with us here in this life the wood is fine. I have saw strick say it before up here "wood is not the enemy" if done correctly the wood will last 30+ years easy. I am using wood in most of my projects and feel like it will out last me and I am a young fellow. On the race boat I will use composites, carbon fiber, coosa, and such but weight will be a big factor on that. One other thing that comes to mind is the resale value. If you are building it to sale composites help sell a boat, but to keep for yourself wood would be my choice. I also think sometimes a heavy boat will ride better and if you get a boat too light it will loose the ride quality but gain some fuel economy. The trick is to get a good over all balance. If your going with a large heavy four stroke stroke on the back you might want the coosa in the rear to help offset the motor weight. I used foam composite core on my bracket build for my 20' because of the 465lb motor on the rear not for the rot free advantage but to try and offset the motor weight for balancing issues.
Old 10-10-2013, 04:21 PM
About 20 hours into the tear down at the moment from the time I started messing with the boat.
Secured the top cap to be removed off the boat..
Top cap removed..
Removed forward fish boxes....
Boat is officially STRIPPED!!! Now it's time to start building her back up!!
