Thats an interesting looking seacraft. Did someone play with it before you got to it?
my decks are ok now but if I had to repair later on is there a real advantage to the squares rather then a dull piece of plywood ?
Here is a section of deck I did: I waxed the surface them primed it with a high build primer then layed a layer of csm first then a layer of 1708 then another layer of csm again on top of a mold table.... The first layer of csm is going to be the top of the deck and the csm will prevent print threw of the 1708 from showing in the primer. The other layer of csm is to help bed the wood squares into. ![]() I bedded the wood blocks down in thickened resin... ![]() I added resin that was a little thick in between the squares... ![]() I added several layer of csm over the coring... ![]() Then added a layer of 1708 then on top of that one more csm layer to build thickness and to sand on so I dont sand into the 1708 fibers... ![]() This created a 1" thick lambent that was smooth on the top side for patching a section of decking... ![]()
The foam in the top of the stringers was dry but the bottom had a 1" of water in them. Cut the tops off and started getting it out. There was several holes cut in the tops already where they were filled originally. They never sealed them off after pouring the foam and that's how most of the water got in.
Back to it, finally got some good weather and time to get back on the cc. Cleaned out the stringer boxes and formed them up for foam. Will be raising the floor 2.5 inches and filling them higher for that purpose. Poured 2 part foam let it set then removed forms. Trimmed the top level and beveled the edges. Ready for glass.
Shaped up the foam a bit with the sander and then added a layer of mat then a layer of mat/rover combo cloth over the foam. Then added some cloth in corners of the stringer to help stiffen the tank tray. It was starting to come loose from the side of the stringer so this will help make the tank platform more solid.
Thanks again for the incredible deal on the hull and meeting me so I could get it. She will get some needed attention and love. Hope you are enjoying the new "sf" you got...
