Old 12-09-2013, 10:08 PM
martin martin is offline
I did the exact same on my 76 23 restore check it out.. I cut the old core out nd kept the bottom skin.. It was very flimsy.. And well old so i ground the glass Down with36 grit and layed a fresh layer 1.5 oz mat let set up.. Then went back and fit all the core material in place... Pulled it back out and wet out one layer of 1708 csm up then reinstalled the core material.. Then vac bagged it down.. Let it cure.. Then went back and leveled the foam down... My foam was 13mm or 1/2" so i had to sand it down some.... To level with existing deck glass.. Fethered edges and layed 1 layer of csm 1.5 oz.and 2 layers of 1708 csm up.. This deck is harder then a Brick Bat..and since i am going with a 1/2 ,teak sole..i think this would be fine.. Check out my thread... Martin
Originally Posted by ElBichoMalo View Post
With 3/8" divinycell core material, how much glass is enough? I glassed the bottom of the dininycell with 1 layer 1708, and planned to "glue" that down the what's left of the old glass (there will be some gaps with no old glass). I wanted to glass the topside after the core is all down, filled, etc. Was thinking two layers 1808 and maybe some 1-1/2 or something.
I know the sandwhich construction gets its strength from both sides of glass, so I know it won't be solid with one side glassed, but it is flimsy. I don't want to find out later that I needed more glass on bottom.
All the old posts I found in search were plywood. Anyone with experience or thoughts on this?
Thanks,
Evan
