Originally Posted by Tabman
Due to the stepped hull you are a bit limited with the width and the 12 x 12s seem to be the best option.
Even though they work for Skiblet I would not advise using the ST16s with only one actuator. In September a fellow lost an ST16 by not using the correct mounting plates and only one actuator http://www.offshoreonly.com/forums/g...tic-ocean.html
Tom
Bennett Marine
Tom, what kind of performance issues if any can be expected by going with a wider tab. I was planning on installing 18x12 on my 20SF. I have a 1994 mercury 150 on the transom, I would like to be able to keep bow down in the tight chop I encounter in Buzzards Bay with the least amount of tab in the water. I know Mr. NO BONES runs 24x9 with no issues that I know of. Thanks you.
