In my opinion:
Compressive strength: yes the plywood helps more than foam. Bending: Not likely. The extreme outer fibers take the brunt of the load. Outer fibers being the skins. The math gets complicated because of the different stiffness of the fiberglass versus the ply, the fiberglass might be quasi isotropic- it doesn't care which way the strain goes. But the plywood definitely cares and has different stiffness. And extreme outer fibers of ply aren't necessarily oriented correctly. (But it helps that the shear stiffness is higher than foams, generally.) The higher (but variable with orientation and moisture and condition) shear stiffness of the the plywood generally is also what probably allows the lightweight inner skin, as the load is transferred to the inner skin better, when the plywood is dry. So the math on a dry transom might work out fine as is. A foam core probably will need more laminate on the inner skin. But the foam should never loose its shear stiffness. Plywood will as it gets moist. I can't say on pure tension. I think the tensions loads are usually a load that goes with bending. Executive summary: More glass on the inner skin with a foam core. And no weight penalty and no rot. Or: More glass on the inner skin with plywood. It will be overbuilt and heavier until the plywood gets damp. Then it will be less underbuilt. And even heavier. In either case, I would be interested in a solid laminate around the I/O penetration. Quote:
