Old 02-12-2014, 10:08 PM
Which tank you want to put where probably depends on how the boat is balanced. You probably aren't too stern heavy with an E-TEC unless you have a bracket, so maybe it doesn't matter, but if you need a bit more weight up front for better balance, I'd be inclined to put the small tank that you use most up front. For when you're making a long trip and fill both tanks, just put as much gear as you can up forward to help offset the weight of the fuel aft in the big tank, and burn off that fuel first.
