Old 12-03-2013, 12:04 PM
Default 1974 20' SeaCraft SF CC rebuild
1974 20' SeaCraft SF CC rebuild.
I decided to hold off painting the other 74' 20' sceptre project till the first of the year once it warms up a bit unless I can talk someone into letting me use their paint booth. So this little sf cc goes under the knife instead of finishing the first sceptre project of the year. I did do the electrical wiring on a paint booth few years back at a local car restoration shop and maybe I can use it but as of now I am going ahead and starting on a second "winter" project to keep me busy. Plans are to finish the work on this one so both can be painted at the same time in a few months once it gets back warmer outside. Wanted to start on the race boat but it will not fit into my current work shop and I dont have the new building addition for it finished yet either will it be heated so this 20'er went under the knife instead. This section of the building is heated so no worries with the resin kicking off or working in the colder outside temps. You northern guys are laughing but it can get cold here in NC too!
Attachment 5923
Old 12-03-2013, 12:27 PM
The transom has been done recently and is in great condition and just needs a little cleaning up. Most of the rest of the boat is in nice condition as well other than the floor. It has a few soft spots here and there. Last night I started looking at the soft spots in the floor and found that it was worst than I thought. So I did a little digging at it and then realized it needs to go. All of it. It looked like someone redone most of it minus the 12" edges closest to the outside of the hull at some point. In the pics you can see where the balsa core is gone around the sides of the floor and where the newer squares of plywood had been changed had soaked up water from the places where the original balsa was left. The new wood was not rotted yet but soaking wet and getting soft. You could not tell this till it was cut into. The wet squares felt solid standing on them but in a year or two all of it would of been soft so I figured the best thing to do is replace all of it. I started cutting out just one spot to see what I would be up against but keep going till I had most of it out. Hard to stop cutting once I get going at it. Found out that all the foam in the boat is wet. There was a large block that was behind the tank without bulkheads just soaking up water. It had 2 holes cut in it so the water could drain past it and out the back. Some one cut holes in top of the stringers and refilled part of them with foam. They did not reseal them so it is wet again. I will remove all of the foam and cut the stringer tops out and make them back 2" taller so I can raise the deck up a little to help the self bailing. Here are a few pics of the tear out. Note the chunk of wood that was glass to the bottom of the floor to keep it from sagging down where the stringers were shorter at the back of the boat.
Attachment 5924
Attachment 5925
Attachment 5926
Attachment 5927
Attachment 5928
Old 12-03-2013, 11:35 PM
Thats an interesting looking seacraft. Did someone play with it before you got to it?
Old 12-04-2013, 08:34 AM
I had been redone a few times before from the way it looks. The rear seating was removed and gone. Look like there will be more room behind the leaning post with the plain basic transom lay out that was put back in. Some one recored the floor, well about 2/3 of it. They left the old balsa wood around the edges of the deck and only changed out the fuel cover and a foot down both sides of it with 4" ply wood squares. Later on the transom was looked to be done after wards and the last two foot of the deck at the rear was cored with a solid 1/2 ply at that time. Some one cut 4"x6" holes in the top of the stringers and refilled sections with foam. Not all of the foam but just enough for them to say they did it. There were several layers of white paint & gel coat on the deck where it had been refinish several times. Transom is raised to 25" height. Here are a few pics before I got the sawzaw out:
Old 12-04-2013, 11:33 AM
Originally Posted by Lordwrench View Post
A little history on this hull.
Thanks again for the incredible deal on the hull and meeting me so I could get it. She will get some needed attention and love. Hope you are enjoying the new "sf" you got...
Old 12-04-2013, 06:46 PM
Spent this afternoon removing foam.
Old 12-04-2013, 09:37 PM
my decks are ok now but if I had to repair later on is there a real advantage to the squares rather then a dull piece of plywood ?
82 seacraft 20SF
Bayview Canvas
Old 12-05-2013, 02:29 PM
From what I understand doing the small squares will help keep the deck from warping up and also it is a much stronger way to core the deck. You can curve or crown the deck to help the water to drain if you wanted and could do curves this way too. Also if you space the squares out a small bit once you bed them down and then pour thickened resin between them it creates a fiberglass grid that is supper strong. If you get a screw hole in one section it will only get water in that square compartment that the core is in. This contains it there, keeps it from spreading to other squares and stops it from rotting the whole deck. Plus most of the strength comes from the fiberglass layup and not the core itself and doing it this way the decking relies more on the lay up and the wood is just a filler to fill the void.
Here is a section of deck I did:
I waxed the surface them primed it with a high build primer then layed a layer of csm first then a layer of 1708 then another layer of csm again on top of a mold table....
The first layer of csm is going to be the top of the deck and the csm will prevent print threw of the 1708 from showing in the primer. The other layer of csm is to help bed the wood squares into.
I bedded the wood blocks down in thickened resin...
I added resin that was a little thick in between the squares...
I added several layer of csm over the coring...
Then added a layer of 1708 then on top of that one more csm layer to build thickness and to sand on so I dont sand into the 1708 fibers...
This created a 1" thick lambent that was smooth on the top side for patching a section of decking...
Old 12-05-2013, 06:29 PM
The foam in the top of the stringers was dry but the bottom had a 1" of water in them. Cut the tops off and started getting it out. There was several holes cut in the tops already where they were filled originally. They never sealed them off after pouring the foam and that's how most of the water got in.
Old 02-22-2014, 11:39 PM
Back to it, finally got some good weather and time to get back on the cc. Cleaned out the stringer boxes and formed them up for foam. Will be raising the floor 2.5 inches and filling them higher for that purpose. Poured 2 part foam let it set then removed forms. Trimmed the top level and beveled the edges. Ready for glass.
