Old 04-09-2014, 10:49 PM
Billpotter Billpotter is offline
Looks good Flex; keep the pictures coming-
Bill Potter
18' 1978, Yamaha 130
23' CC 1986, T Suzuki F115s (current full custom project)
Old 04-12-2014, 08:40 AM
Nice work. I haven't done any vacuum bagging (yet), but I use a lot of peel ply. As you mentioned, no blush, and no sanding required to get a good secondary bond.
Blue Heron Boat Works
Old 07-11-2014, 03:49 PM
FLexpat FLexpat is offline
Made a little progress over the last couple of trips – finally getting around to posting pics.
The transom is completely glassed in now – on the edges I used 5 layers of 1708 wrapped progressively 3-5 inches into hull (each layer farther in). Made forms for the stringers with scrap 1808 over a piece of 2x8 wrapped in plastic and used a piece of Coosa for the keel. Used cabosil w glass fiber added to hold them in place for final glassing. Also put the vent boxes back in with cabosil and glass fiber. Covered everything in peelply to make the final glassing easier but I am not vac bagging this stuff – I don’t know how to get a good enough seal. I am using fiber in the cabosil since the port vent box had broken loose where the potter putty had cracked completely through.
Since I tapered the top edge of the transom core and the vent boxes were matched to the original untapered core, they were not long enough to reach the core on top but did fit on the bottom. I used a piece of a plastic ‘For Sale’ sign as a form taped inside each vent boxes when I glassed them in (after the cabosil). It worked very well and released from the epoxy nicely. 3 layers of 1708 got me the thickness I wanted there. A piece of 6 mil poly plastic taped to a 2’x3’ piece of thin plywood works pretty well as a small wetout table.
Glassed the stringers and keel in with 4 more layers of 1708 and covered w peelply. I put a ¾” drain tube through the stringers – aft of the original – to eliminate the water that would stand there. The original drains would plug with leaves (still don’t know how those got in there) and were not far enough aft.
Made new engine beds out of 2 layers of ¾” Coosa. The top layer of Coosa is 3 inches wider than the original and has a 15 degree bevel on the bottom to match the middle hull panel deadrise.
I did this to eliminate the problem where the old beds trapped standing bilge water on the outside of the beds because they formed a low area over the middle hull panel. Vac bagged the ¾” pieces together with a layer of 10oz between them and 1708 on the bottom.
I used some 1 ½” Coosa strips with a 20 degree bevel as the vertical part from the hull to the bed horizontal surfaces and a strip of 1708 on the inner bond line (inside the hollow base). The forward edge is also closed with coosa to keep water out of the hollow base.
Fit checked the rough trimmed engine beds after the stringers and keel were done. The beds will get glassed in with a couple of layers of 1808 and 1708 on the next trip. I will try to vac bag them in if I can get a good seal. I still haven’t figured out if I’m going to foam the void inside them but it sure seems like a pain for not much value.
Old 10-14-2014, 12:21 PM
It’s been a while since I have been able to work on this – earning a paycheck keeps getting in the way but I do need the cash flow. Finally got around to glassing the engine beds in. Stuck them down with a blend of epoxy/cabosil/chopped glass fiber; it worked pretty well. Then glassed them into place with alternating layers of biax; 1708/1808/1708. Each layer of glass was slightly larger to blend it into the old surface smoothly and minimize how much sanding/fairing I have to do. Since I didn’t have help and was using a fast setting epoxy, I didn’t have time to vacuum bag it but I did use peel ply. There is more resin in the glass than I wanted but I mixed up enough resin for each layer based on a 1:1.5 glass:resin ratio so it’s not excessively resin rich. In the photo below I left the peel ply on the top of the beds to protect the surface until I get around to glassing in the motor mount risers- that probably won’t happen until after I cut the drive hole and figure out exactly how tall they need to be. At least I finally got rid of those low spots outside the motor beds that trapped standing water/oil/funk.
The two biggest things remaining (before paint) are recoring the decks and putting the engine/drive back in. I want to wait til it’s plenty cool before I cut the decks and start grinding again.
I’ve spent a lot of time figuring out where to set the cav plate of the drive when it goes back in. Power is a 5.7/260HP (for now) and a Bravo 1X 1.65 ratio drive. With an I/O, I don’t have a lot of options for adjustment after I cut the hole. Based on talking to several folks it seems like the 23 Sceptre (w/o a bracket) likes to have the cavitation plate between 2” and 2½” above the bottom of the keel. I’m leaning towards having it at +2”. Once I cut the drive in, I can still lower the cav plate by putting in drive extensions (¼” or ½” increments cost 300-500 each), but I can’t raise it further. Any additional input on drive height is welcome here!
Raising the drive means that the engine will come up in the bilges and the exhaust manifold tops will be getting close to the engine box. With the lower engine beds + raising the engine I will also need to get the tallest trunnion style front motor mounts I can – anybody have a set to sell?
Old 05-26-2015, 10:49 PM
OK - I have been derailed by work and a bunch of other stuff so I haven't put anything about my 23 here for a while. I got a little bit done on the motor and got to work on the outside of the transom. Decided to raise the outdrive 2" from the original hole - instant opportunity for patching. Since I am trying to use gelcoat instead of paint I had to pay the extra work price. I used some VE to lay-up a layer of glass and used epoxy to put into place in the old drive hole; it is a tie bond layer so that I could use VE for fairing the hole and gelcoat on top of that.
Sanded it smooth except the part that will be cut out for the drive and sprayed it with some gelcoat - took a chance on color matching and lost, but it was good practice. I probably should not have masked it with tape but since the color didn't match I had to sand a lot anyways. I have never sprayed gelcoat before so this is a big time learning experience and I see that red isn't very forgiving.
Sanded it down and used a drill fixture to mark the cuts for the drive and drill the bolt holes.
Forgot to take a pic of the final sanded transom but it will get some more gelcoat on it before I do the final drive hole cutout - hope I get a better gelcoat match next time. The final coat will be over the whole transom so that if it isn't a perfect match (likely) it won't be so obvious.
Old 05-27-2015, 04:58 AM
bgreene bgreene is offline
I'm going to bet this isn't your first rodeo !
Looks like boat will be a tank when done, good reading too.
Old 05-28-2015, 10:36 PM
I've played with a few boats and spent way too many nights at a Holiday Inn...
