unfortunately not much progress but did cut out the stringers where they attached to the transom...only sign of moisture was around the drain....notice the black marks where the drain was
when I cut out part of the center/ keel stringer it was saturated but solid...if there is such a thing. should I be worried? the lower pic shows the section of keel stringer I removed. again, it is solid but not mush. Thoughts?
I think it isn't that big of a problem - I remember reading a thread here where someone discussed this - IIRC the thought was that the glass on the center stringer is thick enough that the wood is not really needed for strength - it could be a hollow stringer and work just fine. Based on that, I just let mine dry out when I discovered the same thing - wood fine but pretty damp and very thick glass.
thanks for the input Flexpat....that's kinda what I was thinking too....
Fatcat had the same issue with my I followed it back maybe 18" or so where I found clean dry wood ?cut it on a 45 and potter puddled a new PC back in and reglassed it Back in
thanks, I have it cut back about 14" now and I think going leave it open, then glass in a support on top of the stringer back to the transom. that way water wont sit on either side and I can relocate the drain to the center. someone else on here did that and it seemed like a pretty goo idea
here is what I was thinking.....saw this in another thread....
