  #27
Old 07-10-2014, 06:10 PM
After 7 coats of primer and fairing I finally got the hull to smooth enough finish that I felt good about painting over. Started on the bottom side with a very light grey that will be the final finish on the bottom. I don't plan on keeping it in the water no longer than 2 days so no bottom paint. This is the first coat. It came out super smooth with no problems other than one or two nats in it. Turned out slick as glass. I used a 2 part poly urethane called perfection from interlux. The sides will be blue and the inside white with the original floor pattern back in it with non-skid
