Old 08-03-2014, 07:53 PM
martin martin is offline
Default bilge
Engine compartment.. Still need to grind some on the keel area.. And finish the void in the out drive area... There was an air void in between the two layers of fresh glass and the new transome.. There are three layers of 1808 on the ply core.so it will be fine. Plus the glass on the inside skin is over 3/8" thick.. Coring with 1/2" composite then grind down and bed a skin of poly and fiberglass 1708..with epoxy and cabosil.. That way I won't have a delam issue later. Cause everything from here will be polyester...
