Old 08-27-2014, 08:34 PM
Great info. Thank you all. I will report back how my next one goes. Transom came out great but it was different cloth and different resin. Although I did use uncounted yards of 1708 and many pails of polyester on my bass boat and never had this issue.
Old 09-11-2014, 09:50 PM
My second stringer came out perfect. I skipped the squeegee and just rolled it. I tried using my fiberglass roller but the surface was too irregular and was making matters worse. I put a tiny bit of cabosil in the resin and worked the roller till it was just about jelly. Came out great. Thanks guys.
Old 10-26-2014, 05:48 AM
FAS FAS is offline
its always good to wet the surface to be glassed, and also use a wet nap roller,and wet the backside of the 1708 as you lay it down.just fold it up 1/2 at a time,wet the back and lay it down.this will help it saturate all the way through.looks like your layup is fine...
Old 10-28-2014, 11:10 AM
shine shine is offline
Moderator
for hand layup, thats not too bad
