Old 10-31-2014, 09:48 PM
fly4navy fly4navy is offline
Thanks Bushwacker…I am going to take you up and try to get that properly set up on the prop next spring. The engine came with a SST VIPER which was terrible and I went back to an aluminum.. Might you have a suggestion as to what I should be looking for?
Thks!
Old 10-31-2014, 11:10 PM
My understanding is that the Viper is a bow lifting prop. Lots of dealers seem to install them because they will probably give the most speed, but I suspect they're not very good for trying to hang on plane at minimum speed to keep from going airborne when you're offshore in a nasty chop! Although your motor is relatively light for a modern clean-tech engine, it's still heavier than what the boat was designed for, so you probably need a stern lifting prop. The BRP Rebel is a good stern lifting prop with lot's of blade area, much like the Merc Mirage, but the 15" pitch model is about 15.5" in diameter, so too large for your motor. My dealer said that the Rebel is primarily used on the 3.3/3.4L big block V-6 motors. I'd suggest contacting Ken at PropGods with info on your boat and the results of the props you've tried and see what he recommends. BRP's range of props is fairly limited, so Merc, Solas (who I think makes the BRP props), PowerTec or Michigan may have a better prop for your boat. If you're looking at one with a 2-piece hub, the BRP, Michigan and PowerTec designs appear to be much more robust than the Merc design that has a reputation for failures of the plastic hub.
Old 11-01-2014, 08:50 AM
DoozleD DoozleD is offline
...Fly4Navy, im the guy that put the engine on your boat, I was going to try and catch you when u drop your boat off, if your bring it in the fall...thanks for the numbers, I will keep an eye out for u!
Old 11-01-2014, 10:02 AM
Outstanding DoozleD.
I checked in with Tom last week and told him the engine ran like a top and I would be bringing it up for winterization in another week or so.
Stand by!
Old 11-01-2014, 10:12 AM
Also, DoozleD,
My scuppers run down through the floor (no transom redo…yet) and my floor stays dry with the weight of the 115 hp. On the hook with engine fully tilted up, there is barely a partial sporadic kiss of the water
Old 11-02-2014, 09:46 AM
wow!!...i have to put the plugs in my scupers or its wet feet!...its not a big deal because i trailer it but that goes to show the weight diff!
