Old 11-03-2014, 05:38 PM
Riley@florida-re.com Riley@florida-re.com is offline
23' Sceptre with 30" offset bracket.
Old 12-10-2014, 01:55 AM
GameOnSalmon GameOnSalmon is offline
Riley... I read on another site.. Tsunami with F350 pulling right at 60mph on the Transom.
I am thinking you should be able to Prop that bugger and Double check the Running height of the AV plate. On the 23' I just sold with a 30" Armstrong Bracket I was (Cough Cough) 5.8 Inches high with a Mirage Prop on a 250 Rude.
My First thought is...that boat should be doing 55 or close too it with that set up.
Worth a look if you already haven't done that.
Robert
Old 12-10-2014, 09:10 AM
Robert
He's not far off with a full tank of fuel and four guys in the boat. I bet it comes out of the hole like a cannon.
Only speaking for myself, I don't put a lot of thought or effort into top speed prop selection or cavitation plate height. Cruise speed efficiency in seas and being low enough not to blow out on a hard turn rank way above squeezing a couple of extra knots out of her in the channel.
Old 12-11-2014, 05:55 PM
Default 55+
The first time I ran the boat by myself I got 55 out of it but it only had 10 gallons in it. It felt like it would keep going too but started getting a little squirrelly!! The torque in the motor is unreal and it will throw you out of the back of the boat if your not careful.
Off subject; Moose, what does that AJ weigh?
Old 12-12-2014, 10:20 AM
If I remember correctly he was 128...... Almost exactly the same weight I have put on since I shot him.
Old 12-15-2014, 09:28 AM
Fish of a lifetime there man!!
