Old 12-04-2014, 08:00 PM
Originally Posted by 76pb View Post
Attachment 9081 put the rear storage back in use and built spash gaurd.
You might want to add some screws to that leaning post if you don't want it to come out in the ruff water on a bad day. One screw in each corner is not enough to hold it down. Just make sure you install it them, then take the screws back out them add some resin with thickener (a syringe works well for getting it in the hole) then reinstall them. This will help keep the core from rotting. Also if you want the screws to come back out ez add some wax to the before putting them back in.
Also welcome to CSC, I see this is your first post. Is this your first SeaCraft hull?
Old 12-04-2014, 10:02 PM
76pb 76pb is offline
Default 18'ft seacraft
Yes this is my first post and yes my first seacraft bought it from boatman 2506 and I have since put all the screws in with 5200 silicone, thanks.
Old 12-06-2014, 06:17 PM
Default 76pb
Like it man! Hope you are enjoying her!!! Everyone tells me how stupid I am for selling that boat.
Old 12-06-2014, 06:22 PM
Default Splash well board
Is that aluminum you used for the splash well board?
Old 12-16-2014, 04:35 AM
Default 18ft seacraft
yes its aluminum probably not the best choice but when it starts to corrode ill just cut out another one.
