![]() Quote:
those alarms - when key is turned to the "on" position,the alarm should sound - if not,check it out and find out why.... few things can make the remote tank pump inoperative - pump itself,trim indicator,float switch,wiring - or a clogged filter odds are,crank is good - you're gonna need a powerhead overhaul/replacement getting the powerhead off can be a little difficult - but,having pulled probably 20/25 v6 powerheads over the years -shift rod replacement,you develop a few tricks...
do not let common sense get in your way |
My ETEC had issues running above 4000 rpm. Finally took it to my mechanic that found when the motor was installed on the boat the fuel line, oil line and shift throttle cables were somehow twisted and kinked causes many issues. The one that I never saw was the issues with the oil line. This motor is an 2009 with only 90 hours when I purchased the boat and motor in the summer. Up until now I was worried I purchased a motor with major issues. The mechanic told me I was fortunate I did not ruin the engine by starving it of oil. I never got an oil alarm, only fuel alarms
![]() Quote:
Fuel starvation is a whole other issue however and has killed many motors of all brands! I suspect that overpowered boats are the most susceptible to this problem. A slight restriction that causes motor to run lean but almost reach full power is probably worse than a severe restriction like you had that's more obvious!
Another lesson learned is to use 100 oil. Another issue was the gage. It only gave a high fuel level alarm no matter what was happening. The mechanic replaced the gage with the new style electronic gage and made sure everything worked. Finally got a printout on the engine. Working properly alarms are a good thing
Display Modes | |
