Got the hole filled and re drilled and it looks great. One last question, in the picture below, can I flange that as is or should I cut it down? The black line is the bottom of the hull. Itis a standard three inch brass tube. Thanks
Chance
I would consider something with more strength and wider flange like (Gemlux S/S). Measure first with locking nut tight in place and flush against your inner liner. Cut the threads down then reinstall, seal it with 4200 and keep an eye on it. Flexing could slip between hulls & crack weaker type tubing. ![]()
