Too impressive. I mistyped my cruise. It is about 24mph for 45-4600 rpm. And 5NMPG.
Thanks for all the feedback. I'm still not 100% sold but leaning toward the Suzuki F175. Its just a couple lbs lighter and a dealer in Mississippi who sells both the Yami and Zuke swares that its ability to turn a larger prop puts it in the same class with the F200 Yami. Your right. Money really isn't the issue here as much as feeling that I made the best selection. Any preferences of the Yami vs Zuke? Most all the reviews I read say the Suzuki performs flawlessly with lots of torque, great mid range and good fuel economy but the downfall is that most say that if they were shopping for a used boat, they are more likely to buy is a Yami is hanging off the back.
The Tracker hulls are not as sensitive as the Potter boats to weight aft. If the boat is intended to run 50+mph in smooth water, and there's no need to be able to stay on plane below 20mph, the CG will want to be further aft than a Potter that's bound for 3'-4' seas.
You might be fine with a 500 lb. 200hp motor as long as you don't hang it on a bracket. Check the bottom of the hull from the transom forward about 4' with a straight edge and look for hook. My 20' '83 Seacraft Industries hull has some hook and it keeps the bow low at speed. If yours has some hook in it, that will work in your favor with a heavier engine. Dave
Dave,
I didn't realize the Tracker models had a hook in 'em! Probably makes sense as they were newer boats and rigged with heavier motors. Is it just the innermost panels or do the other panels also have a hook also? Didn't we find some rocker in the aft 3-4' of the innermost panels on that Potter 20 CC project boat you picked up? I think that rocker would provide more speed potential than a boat with a hook because you could get more hull out of the water at high speed, although it would be more sensitive to motor weight and CG location. I was doing some prop testing in flat water on my stern-heavy rig last week and noticed that, at about 25-28 mph, I could trim out to about 50% trim with no porpoising. As I increased speed at the same trim setting however, it would start to porpoise once I got up to about 35 mph! The '69 Boating Magazine test data (attached) on the 20 Seafari shows an increase in running angle above 35 mph, and I suspect that may be a result of some rocker built into the Moesly/Potter hull. That should provide some extra speed in a normally balanced hull, but if is a hull is already stern heavy, I could see how that rocker could make it less stable at high speed! (Carl said the CG on the I/O models is further forward than on the OB models, and it's definitely further forward than it is on mine with the bracket and heavy motor!)
I'll tell you what Bushwacker, I'm sure disappointed after looking closer at the Suzuki numbers. I pretty well had my mind made up after talking with a dealer that had me convinced that The Zuke DF175 was equal to the Yamaha F200. Before pulling the trigger, I decided to look over the boat tests on the Suzuki website and to my surprise, the DF 175 had the exact same numbers as the DF 150 other than it was getting less MPG on average. They ran each motor on an Angler 220FX (2400lbs) and a Bluewave 2200 (1750lbs). I was thinking that I could get 50 mph out of the Zuke 175 but after seeing that top speed on the Angler is 45 mph with either motor, I have to question if gaining 5mph is worth $5k to advance to the Yamaha F200. Right now, your suggestion of getting something to hold value for a couple years is making a lot of since. Maybe a Yamaha or Suzuki 150 is the ticket for now. Who knows. With the right prop I might even get a little better than the study with the Angler 220FX. I'd like to think the Seacraft hull design would out perform the Angler. It sure would be nice if the Suzuki 140 would get me over 40 mph. That would be an easy choice at 400lbs but it seems like any 4 stroke to push the boat over 40 mph is going to weigh in the range of 485lbs.
Thanks for mentioning the "hook" Dave. I took a straight edge to my hull and I don't see any variation in the suggested area. I'm not exactly sure what I should be looking for but it is straight as an arrow for at least 8'-10' from the transom. When refinishing the boat, I pulled off the cover to the compartment that houses the fuel tank and the tank was at some time replaced with a 35 gal. aluminum tank that I could move aft another 2' if needed. The boat was pretty darn well balanced as it was with the 440lb F115 so I didn't mess with it then. It would be a pain to tear into it again to push the tank forward but I could always do it if the extra 60 lbs from the new motor became an issue.
Denny,
I wasn't sure about the Tracker 20s, or whether hook was something Tracker phased in over time, that's why I suggested the straight edge check. A friend of mine picked up an '88 23CC a few months ago and it has some hook in all the hull panels, both starboard and port. That doesn't mean all the Tracker boats have it. There may have been some changes made between production runs. Who knows? Quote:
There's a lot of "lore" about these hulls, some of it reliable, some not so much. The layup schedule can be significantly different from one boat to another spanning three or more manufacturers. On the '88 23 I mentioned above, my friend pulled the through-hull bilge pump discharge out, and the hull side was 1/2" thick, much thicker than you would expect to find in a Potter boat. I think the take-away from this is that if your boat ran ok with a 440lb. 115, it will be ok with slightly more weight in a higher horsepower motor. I don't have any hard data, but I think the Potter 20s, because of the rocker Denny mentioned, and probably lighter weight, may be faster boats than the Seacraft Industries and Tracker boats with the same horsepower. If you want to hit 50mph, you may have to go to a 225. It's only one data point, but my Seacraft Industries 20 runs mid 40s mph with a 200 2-stroke carbed Merc. Sorry if I've injected uncertainty into the conversation, but there's a bit of a wild card element when we talk about post-Potter hulls. Dave
Please Dave, don't apologize. I'm here to learn and I value the feedback that you all provide. Maybe one day I'll have a nugget that I can offer. For now, your right. There are so many variables to these boats over the years that I have much to learn. It is reassuring to hear from folks out there running 20' Seacrafts of all ages with motors weighing upward of 450lbs. It helps put things into perspective.
PowerBoat Reports did a great comparison test of all the 150 HP motors back in June 2006, so I dug out my copy and have posted the last 2 pages below which contained all the test results. I summarized all the data in a plot vs. RPM. All motors were mounted on identical Angler 204FX 2200 lb, 8'x20'4" hulls. The only gripe I have with the test is that ALL tests were done with the motors trimmed FULL DOWN! I"m sure they would have all picked up more speed if the motors had been trimmed out as far as possible! They did that just to make things equal because they didn't have trim gages on every motor. The tests would have been more meaningful if they had tested each motor at the optimum trim for the particular prop it was running, but I'm sure that would have taken longer, and those guys clearly weren't operating to the same aerospace performance test standards I was used to!
Verch,
You got some good feedback from the guys. I will chime in some here on a couple of notes. I am in Idaho and 80% of what i run is Glass on the Lake. With 20% on the Columbia river which is always blowing up 3' 4' all the time and some Offshore Oregon Tuna Runs. So Here's what i came too... Been an Evinrude guy a long time... Here are some Options... Carb - Johnson Ocean Runner - 150 to 200hp. 380 lbs and Plenty of power. The down side.. .Not so good fuel economy compared to todays Engines. Next up is the Etec - U can Run the Small block v-6 close to 428 lbs and here is the kicker.... 135 HO - Low water pick up and Putting out close to 150 HP. Cheaper than the 150 same horsepower as the 150 or close too it. 150 Etec - Bushwhacker has this engine... Plenty of Torque / Speed but probably not a 50MPH boat. then the 175 or 200 Etec.. .NON G2 .... I strongly Considered the Etec 200. Flying Frizzle put a 225 Merc EFI on a bracket on a 20' Sceptre. Speed 60mph plus... chine walking at 60. Weight 480 lbs With all that being said... Strick has a 140 zuke on a 20' sceptre speed around 44mph on a bracket. The 150 and 175 Zuke are in a whole nother league than the 140. They can spin a big prop and the 140 is not a super strong 140. The Yammies are priced Considerably Higher but hold great Value. I would encourage you to go Look at the zukes again on Test boats between the 150 and 175. Pay attention to the type of Hull those engines are on. When you really start looking most are what i would call a PLOWING type design. Someone Posted Up last year a 23' Sceptere with a 175 zuke pushing 43mph... and that bastard weighs in at 3300 lbs dry. I can tell you this.... I am now Narrowed down too 2 choices for me on the 20' Seafari. The 175 Zuke Mounted on a 10" Hydro Dynamics Bracket with a POWRTran 7" Electric Jack Plate for optimal Trimming and Speed. OR I am going to buy a 1995 to 1998 Johnson Ocean Runner 200hp and hang it on the same set up. The cost between the 2 engines is about ZUKE - $13,000 OMC Ocean Runner - $2000 plus $2000 For Hopped UP Rebuild Total is $4000 plus the Brackets. I am going to make a decision Soon.... I love the Zuke Technology. But Dam i can buy a ton of gas for $10,000 and... have a Super Reliable Engine at 385 lbs with massive Power. The Johnson Set up is probably a 60mph boat plus. Have no idea if that gives you any insight but after Hours and Hours of countless consideration I am down to those 2 choices. Regards, Robert |
