Old 02-15-2015, 09:47 PM
FAS FAS is offline
3m 5200 is listed as permanent adhesive sealant,4200 is more forgiving and is removable.both are gonna be tough to remove.8 ft of 5200 down each side is gonna give you a problem to remove.lotsa stuff out there.. polyseamseal? I will use a white pure silicone on mine,just to be able to raise the deck if needed.
Old 02-15-2015, 09:58 PM
GE silicone or boat life caulk would be my choice. Take some 100# mono and tack it down
first. Let it dry and caulk as usual. Next time the hatch has to come out, just pull the mono out like a zipper. 4200 and 5200 are the devil`s spawn.
Old 02-15-2015, 11:03 PM
keith keith is offline
I like the 100# mono idea, thanks! I will use that one for sure. I'll also check out life caulk.
