Old 04-12-2015, 10:26 PM
Nice score! As a F100 owner, I have some advice to save yourself headaches later: Buy a 10 mm wrench. You will need to drain the carb bowls any time the motor sits for more than 2 weeks. Otherwise you will need to pull the carbs to change or clean the inline filters on the back side of the carbs.
I am curious what you have for a prop. I run a 4B Solas amita in 12-3/4 or 13" diameter by 15" pitch
Old 04-13-2015, 06:45 AM
Hello as the previous owner I can speak of the prop, i believe it is a 4 blade 14X17. The boat will turn 5900 rpms with two aboard, sad to see it go but lifes priorities dictate it. Best of luck to John.
Old 04-13-2015, 07:24 AM
John3325 John3325 is offline
Thanks again Alan, like I said before I am pretty excited to get into this one.
I can confirm the prop size later on today when I get back down to the boat.
Thanks for the tip FishStretcher. I actually work down Continental Marine in Quincy, MA as a part-time outboard mechanic (did it through college and still do some work here and there). I primarily work on 2-strokes, haven't gotten into the four strokes as much but that is great advice draining the carbs even if its a few weeks.
