Is my winch correctly mounted? Are these the correct straps and tie down for my boat?
its tough to tell in the pictures. Try some shots during daylight hours and i'm sure we'll be able to help.
I would remove the galvanized shackle
Shackle is for pulling a tube. Only have shackle in place when using the tube?
The winch seems to be at too great an angle to me. I was told I should have straps aross the gunnales from side tio side. We used to have a strap there, be we started seeing a lot of gel coat cracking in the area of the strap.
![]() Quote:
Looks like an EZ-Loader roller trailer? If so they're a great trailer, but there is one thing you need to be careful of . . . there is so little friction in that roller system that it's very important to use the safety chain on the bow and not depend on the winch brake to keep it from rolling off the trailer! I also use a VERTICAL ratchet strap on the bow eye to prevent it from riding up on the winch stand rollers if I have to make a hard stop! Your stern straps will not prevent it from rolling forward. I prefer a strap that wraps over the gunnel at the stern. One suggestion on your roller alignment . . . spread all the rollers as far apart as possible, and then move the racks outboard until the outer rollers are just outboard of the outer step. That way, the outer rollers will guide boat on trailer. Before I did that, I found that the roller system has so many degrees of freedom that if boat was laterally unbalanced/heeled to one side at the dock, it would come on the trailer the same way! Once you move the rollers outboard, boat will come on trailer perfectly straight every time regardless of cross winds and/or current! Move winch stand forward until aft rollers are right under transom. I also added keel rollers on front and back side of aft X-member because the SeaCraft hull is so deep up forward that keel will hit X-member before the aft rack of rollers contact the hull. You may have to dunk that tandem a bit more than I do (I don't even get the rims wet . . . I just back it in till the tires are wet and aft keel rollers are an inch or two below bow eye. This trailer has been used for 30 years in salt water with original springs and axle still in great shape since they are never dunked. Had to replace aft X-member a couple years ago because thats all that ever gets wet!)
I love this forum. Tons of great advise. Normally the chain is kept tight. I will be looking into the yellow rollers. I get black marks down the hull from the rollers when loading the boat. Once the boat is centered, the rollers do guide it on the trailer. If the boat isn't centered, pull her back & try again.
![]() Quote:
If you install a couple keel rollers on that aft X-member, that will keep boat centered until the outer rollers lock on to the outer step. I tried just using just one roller back there, but discovered that the aft cross member tilts so much during launch/retrieve that keel would scrape on front edge of X-member or the mounting straps, so you really need a front and back roller.
I agree with Bushwacker's advise. I also agree with pelican's comment on a winch style strap and binder over the boat. We haul heavy machinery on a flatbed trailer. You really have to be prepared to know that the boat is unitized to the trailer for unintentional jack knife or off road situations. It's an unsafe load otherwise. We also like the vertical strap on the bow. The "safety" chain won't keep the bow on the trailer in a worse case scenario, which is what we are really concerned about.
Otto And yes, I still believe in the four boat theory... |
Wow, ya sold us on 2 straps over the boat. Got the bow rollers changed. Are the support rollers under the boat in the proper positions? They get replaced next. Can I safely use a floor jack to lift the boat to replace the rollers?
Display Modes | |
