Thread Tools | Search this Thread | Display Modes |
My MPI has no return and pump is on the engine. Water separator is on engine, too.
The biggest differences I am aware of to watch out for in a motor swap are the new style rear mount bushing and the new style wiring harness on late model MCM motors:
![]() Quote:
![]() Quote:
Thanks |
Repowered my 23 with a 357 Mercruiser Reman. Was told by rep they used new blocks and bore over to make it a reman. They also add mechanical fuel pump. Bolted right up to transom ass'y. You would have to check the drive ratio to make sure you have a 1.47 set. The gear set is in the Outdrive.
I am very please with the set up. runs like a scalled cat. If your interest in a 4.5 FWC MPI new left over call Marine liquidaters in Fort Peirce, they had one there in Feb. for 5500. |
Thanks Bobbert. The 357 reman is one of the engines I am looking at. It is either that or the 5.7 mpi remanufactured. I guess you had that choice too. How do you like the new motor? Any regrets not going with the MPI?
I have 1.62 gears and have been told that I can re-prop instead of changing them. |
Just LOVE my 357. Gets up and goes, very economical. Picked the carb over MPI because we have big Ethanhol issues. Here it can run 5-14% and really does a number on the MPI.
This 357 is a Mercury motor, not a secondary builder. Hot run test, 2 year warranty, etc. As far as the drive ratio, I would spring the bucks to change to the 1.47 ratio. You could diddle with the prop but it would be a compromise situation. Buy the way it was a quick Drop in install. |
![]() Quote:
He said you can run a 25 micron separator with MPI, 10 with carb. Who knows? |
![]() Quote:
While you have the engine out inspect the bottom of the Y pipe (exhaust) very closely where it bolts to the transom housing - the one I removed from my 23 was corroded very badly and the lower bolts had nothing left to attach to.
Display Modes | |
