Old 07-25-2015, 09:30 PM
Is it the pedestal or the screws coming out of the floor?
Old 07-25-2015, 11:15 PM
keith keith is offline
Definitely the pedestal. Specifically where the tubing goes into the base. The upper half where the seat bolts is fine.
Old 07-25-2015, 11:36 PM
htillman htillman is offline
Post pic. I've got a couple old ones
Old 07-27-2015, 03:00 PM
Default Pedestal Seat
[QUOTE=keith;237687]Definitely the pedestal. Specifically where the tubing goes into the base. The upper half where the seat bolts is fine.[/QUOT
I had this problem a couple of times on my 1976 20' Seafari pedestal seat years ago. The problem is the tube is fillet welded to the flange only on the underside of the flange, apparently so what is seen looks better. I had it rewelded and the same thing happened again. After the second failure, a different weld shop put a fillet weld underneath and on the top of the flange. I have had no problems since.
Capt Terry
Old 07-28-2015, 11:21 AM
Here are two pictures. One leaning back and one forward, which is pretty much straight up.
Old 07-28-2015, 11:23 AM
[QUOTE=Capt Terry;237726]
Capt Terry
Terry,
That makes sense to me. I will take it down and give it a look and see if I can get it welded. Thanks for the advice!
Keith
Old 07-29-2015, 08:21 AM
Default Pedestal Seat Replacement
[QUOTE=keith;237744]
Terry,
Keith
In my jet engine design engineering experience, our company avoided fillet welds as much as possible. A single fillet weld was never allowed because there is basically a crack on the non-welded side of the joint. So if fillet welds were used there needed to be two, one on either side of the joint. Picture an upside down "T" with a fillet weld only on one side of the base of the "T". As the vertical leg is loaded back and forth the built-in crack from the non-welded side will continue to grow. It's a lot less likely with fillet welds on both sides of the vertical leg.
