Old 02-06-2016, 11:15 AM
shine shine is offline
Moderator
exact opposite . . . Honeycomb where you DON'T have rod holders, cleats, etc. You want to use the HD foam or plywood where you mount hardware or any place that needs compressive strength or needs to hold a screw or bolt.
Yup, honey comb everywhere except for where you have fasteners. The honeycomb actually has excellent compression strength except for the edges (anywhere you cut a hole in it). It does not hold screw either, so that is the second reason to use ply/foam around rodholders, cleat, etc.
I would use 3/4" core, its really just barely heavier, but much stiffer than 1/2" core
