Old 06-28-2016, 07:43 AM
shine shine is offline
Moderator
You missed a spot!
I actually did. Im going to give it another coat next week. I was trying to do it on one coat, but it needs two. Unfortunately for me, that means one more sanding.
I have one you can re-do. Ron.
haha, I will paint it for you if you want
Shine indeed.
Old 06-28-2016, 09:53 AM
Old 07-27-2016, 08:36 AM
Moderator
roll over cradle is finished, now just have to roll it outside and get a piece of equipment to pick and roll. *
Old 07-30-2016, 08:54 AM
Moderator
A few pictures of the flip. *Have a short video on another phone. * The google gallery for this build has all the pictures. *
Rolled it over almost all the way. removed casters from top and relocated them to the bottom before setting it all the way down. *Spun the hull around and rolled it back in the shop (bow first)
Old 08-08-2016, 09:05 AM
Moderator
starting the interior glassing...
Started glassing. *
Old 08-08-2016, 11:16 AM
Joel, How many times do we say - "Use the right tool for the job!"
You don't use an excavator for a crane! - well, unless it's a lot cheaper! (Remember, we're all a lot like Don V. - the cheap Bas#@&d)
PS - The boat looks cool
Old 08-08-2016, 12:21 PM
Moderator
Haha, well the crane rental place would not even return my calls, and the digger was free That thing had an extendable arm that reaches well over 16', could probably roll over a boat twice the size. "turned" out to be the perfect tool for turning
Old 08-08-2016, 12:36 PM
"and the digger was free"
As T-3 would say...."free is for me and that makes it the right tool"
Old 08-12-2016, 08:31 PM
Forklift with carpet pole.
Tank comes out.
Lift hull off trailer with fuel fill hose.
Wait til morning.
Repeat as necessary.
Fall for the race boat.
Shine,
Wish you were my neighbor.
Bones too.
Sweet work.
Old 08-12-2016, 12:34 PM
Moderator
transom core is epoxied in place.
Dry fit, wet out surfaces with neat epoxy, apply epoxy glue (a mix of silica and wood flour), clamp/screw into place. both surfaces were very flat with a very nice fit, did not need a ton of glue. Used about 2 quarts of epoxy (before thickening)
Total core thickness is 2.25" Design did not call for that much, but a had the 1.5" foam core, and it didnt add much weight. With the full size bracket, the loads are spread out over a large area, so the transom core really only needed to be 1"
