Old 05-21-2016, 10:21 PM
Negative on the starter removal....
Get your self a can of WD-40 Easy reach
Remove the fly wheel shroud cover and spray away...
Cycle the starter with the kill switch clip removed (if equipt) or spark plugs out..
Done deal...
The bendix is just sticking and cannot fully engage the flywheel...
Had to do my old 75 HP Johnson every couple of years.
Old 05-22-2016, 08:27 AM
No kidding Ken, I thought this process should have been placed on page one of the maintenance section of the owner's manual. Every one of the six old style OMC engines I have owned required steady lubrication maintenance on the bendix starter shaft. If you let it sit for a few months it was automatic the bendix would stick.
Old 05-22-2016, 08:55 AM
Default Starter Bendix
My last Merc 150 lasted 28 years. It sometimes needed a shot of WD-40 as well on the starter Bendix. For saltwater usage also sprayed the entire engine under the hood when brand new & once in a while with CRC soft seal.
Old 05-24-2016, 07:57 PM
TomParis TomParis is offline
Ok I got the Dry Lube and I am ready to go, but here is what mine looks like, I am unsure what I need to remove to access the shaft and benedix.
Any help is appreciated.
20160524_194600 by TomParisOBC, on Flickr
20160524_194603 by TomParisOBC, on Flickr
Old 05-25-2016, 10:44 AM
My understanding is these motors will not even spark, hence start, unless the starter is cranking the motor at a certain speed. ECM will say no sparky, no go. I got a free FICHT and changed out the starter, solenoid and the wire that goes between the two. The starter was around $80, and pretty sure that was the issue on mine, corrosion showing, 15 years old, etc. It would crank great but after changing the starter, it cranked a bit faster and started right up. Low battery or even a new battery without enough cranking amps would have the same effect.
