Old 06-08-2016, 09:10 AM
TomParis TomParis is offline
Default Fishing the flats by the St. Marks Lighthouse
Went out fishing yesterday evening, was cool we were the only boat out and caught some nice trout. See pictures below. The only problem was when I got back the trim motor didnt work, neither control the one on the motor or on the console dash worked. So I assume its either a bad motor or bad connection.
13393958_10208363809705757_299664315161106332_n by TomParisOBC, on Flickr
13417698_10208363810145768_846554566140026632_n by TomParisOBC, on Flickr
Old 06-08-2016, 09:38 AM
Sometimes a storm wakes up the fish. I would probably be out in the ocean now, if it were not for the off shore moving storms around here.
It could also be a relay on the engine.
Old 06-08-2016, 10:42 AM
Considering the relay is like 15 dollars and the trim motor is over 100.00, I think I will replace the relay first!
Old 06-08-2016, 01:56 PM
Good chance it's the relay. Whenever that happens out on the water, try tapping the relay to wake it up!
Old 06-08-2016, 03:09 PM
I was thinking, 100 dollars for a trim motor? Then I remembered no, you didn't have a Yamaha.
Old 06-08-2016, 03:39 PM
I will try the relay first, and that price is off Amazon not from local Evinrude dealer.
Old 06-08-2016, 03:59 PM
Trying to remember, I think there are two relays on those OMCs? If it's not going either up or down might be the $100 item. If it's going just up and not down you can switch the relays to isolate the problem.
Old 06-08-2016, 06:32 PM
76Red18 76Red18 is offline
Unplug your tilt limit switch and see if it works.
J. M. Hendrix
Old 06-08-2016, 10:58 PM
its not doing anything when I push the button on the console or on the motor. It was working before we went out, and we returned to the ramp to load the boat nothing.
I was going to replace the relay since its less than 20 bucks, I will report back after changing that if that doesnt work.
Old 06-09-2016, 03:04 PM
So, he's giving you 3500 trade in on your throw away motor. That's not too bad.
edit
I was looking at the price of a 150 at 12500. I actually don't know what hp you were talking about.
