Old 09-13-2016, 02:47 PM
Originally Posted by TPG View Post
Has there been any documentation done on how far to move and what to move depending on weight of motor?
Check out this thread, posts no. 15 & 16. Based on the successful experience both Connor Davis and I have had with cramming the Seafari's large cabin full of gear and dive tanks, I believe it's very difficult to get too much weight forward in the 20' hull! It seems to have plenty of lift and buoyancy up front. I've run with 4 dive tanks plus a bunch of gear in the cabin, resulting in a great ride in very rough seas and Connor has run with 6 tanks in the cabin with similar results. I also concur with Connor on power . . . my "150" E-TEC (actually 165 hp at the prop) has so much mid-range torque that I've never used more than 50% throttle when getting on plane, and I typically cruise at about 25 kts/3700-3800 rpm and about 35% throttle. I hardly ever use all the power available.
If you stay with a ~400 lb motor, keep the casting deck, and move the console, batteries and gas tank as far forward as possible, I think you'd have good results. You might ask No Bones how far he moved his console, as his rig seems to be well balanced. If you add a bracket, you'll also want to add some large trim tabs, a 4B stern lifting prop, and maybe a fin on the AV plate.
