Old 09-20-2016, 11:40 PM
Denny and Suzie, falling in behind to let you whippersnappers locate the rock piles by Braille!
You're very observant Mr. Commodore! I remembered your advice for "Navigatin the Nature Coast" from our Homosassa Gathering, so I was indeed a little nervous about leading DonV, Vezo and Snookerd over to your lunch raft-up in unfamiliar waist-deep water without the visibility I was used to in the Bahamas! Had Susie calling out depth readings while I watched for rocks and decided to drop off plane when depth dropped to 4'! Although DonV is certainly no whippersnapper, I decided that it would be a lot less stressful to just follow his deeper draft 23 out of there instead of "plowing new ground'!
Terry, you and Marsha have set a new standard for hospitality and coordinating & organizing this bunch, which has to be about like trying to herd a bunch of cats! Susie had a great time, and after she tasted some of Doug's scallops on the half shell, she definitely understood what all the fuss was about! Thanks again for all your effort in pulling this event together! Denny
