SIMPLE ANSWER Don't know what your engine weighs (check the internet). But let's say it's 200# more than the original & without a bracket assume it's CG is 0.5' aft of the transom, This results in a negative 100 Ft.Lbs. about the reference point of the transom. To compensate for this you want an additional positive 100 Ft.Lbs. added forward of the transom. If the console weighs 100# and that's the only thing you will relocate then you will move it forward 1' If two batteries are moving with the console, let's say that's another 100# (you can weight them), then the total 200# would only to need to move 0.5'. Without a bracket the change is not so severe, probably better off with a cooler of beer between the console & the bow. |
("Incoming") Signed Keyboard Cowboy T-3 |
Think of people as trim tabs. |
Some are even the Lenco "Short Stroke"!
Caymanboy has the best selection of trim (tabs) I've seen lately
Well, maybe two! |
Both can be considered "HIGH" maintence......
Those Lenco's have a high rate of failure with routine replacement after high useage ! ![]()
See ya, Ken © |
So how does one figure out or calculate the center of gravity of a hull to do the calculation if a motor is already mounted on the transom. I have an 18SF that at some point in time will ultimately have to replace the 1998 Yamaha C115 @ 330lbs with a heavier four stroke and would like to know how far forward to move the 40 gallon fuel tank and or the center console.
Denny, have you ever been able to put enough weight in your cabin to make your Seacraft "plow"? I have loaded so much crap in the front of mine that it sat bow down at the dock where the winch eye was in the water, but when I get going it still runs with the bow up and handles perfectly. I don't have much of a motor back there to counterbalance the weight either. Has anyone on here ever moved their gas tank and batteries too far forward to make the VDH hull plow? Just wondering?
