![]() Quote:
Check this out: http://forum.woodenboat.com/showthre...-Plywood-Tests Termites had no interest in Meranti. 71's have 4 stringers that are glass too. |
Rock on Brother, you'er set.
It might have been the 1X12 pine stringers in the V-17 Wellcraft that were half ass, half glassed or somethin' like that too. The boat had a 1/4" hull with a 3/4" plywood core on the floor liner - felt solid as an 8" monolithic concrete slab when you stood in it. Gelcoat and amenities were spectacular. It helped sell a lot of those boats. We work boats 10 months out of the year in Florida. If things ain't right it shows up soon here. |
Why is there sand and errant ring terminals in the stringer?
![]() Also does anyone have the dimensions of the tanks they put in the boats from 72 on? |
Did you save the Hull ID#, I hope.
And thats all the core removed. Onto the sanding and marking areas that need to be ground and glassed.
When I get the funds, I am planning on repowering with an ETEC, and I think I want to rebuild my transom at that time whether it needs it or not.
I have been thinking either the Coosa Board for the transom repair or going the Seacast way. What do you guys think about these alternative methods to Marine Plywood. |
![]() Quote:
seacast is only 200 bucks for 2 gallons, based on the instructions if your fiberglass on both sides is still good, which mine is would seem to be pretty simple.
http://transomrepair.net/ |
![]() Quote:
Display Modes | |
