Old 10-29-2016, 08:14 PM
Originally Posted by ericallen01 View Post
. . . If weight was an issue, why were the 20's offered with so many different v8 sterndrive options? Those small blocks must be close to 7-800 lbs with the drive and steering.
CG is much more important than weight, ie., it's all about where the weight is located. Carl Moesly told me that the CG on an I/O Seafari with the 4 cyl MC is further forward than it is on the OB version with a 300 lb motor on the transom! I think those V-8 I/O's are closer to 900 lbs, but the CG would probably still be further forward than it'd be with a 500 lb 4-stroke hanging on the transom!
Old 10-29-2016, 08:39 PM
CG is much more important than weight, ie., it's all about where the weight is located. Carl Moesly told me that the CG on an I/O Seafari with the 4 cyl MC is further forward than it is on the OB version with a 300 lb motor on the transom! I think those V-8 I/O's are closer to 900 lbs, but the CG would probably still be better than a 500 lb 4-stroke hanging on the transom!
Could be.
Could be.
He understands much more than most of "We".
Old 10-30-2016, 08:21 PM
TPG TPG is offline
Vortec with 71C is 900lbs, with an I/O probably over 1000.
Old 10-30-2016, 08:53 PM
I used to see a gal and her young squids in a 4 cyl version. For a bit.
And then they would pull away into the sun.
I guess I need to get me some Lencos.
Old 10-31-2016, 08:31 AM
I think you meant to say Bennett's.
Old 10-31-2016, 08:20 PM
Maybe the only thing that won`t break.
Old 11-01-2016, 08:44 AM
How true Sandy!! I had Lencos on my 22 Pathfinder, the best thing about them was the actuators were easy to replace, a couple of screws, splice the wires and prepare for the next replacement. I would buy two when I found a good deal, nice to have a spare at home. Plus the old ones looked right at home in the garbage can.
