is motor perfectly centered? Does drive leg have torque tab? slightest bit off center can cause the bow to lean... Fuel tanks flat bottom or v? is fuel sloshing side to side, a'la the mitchman effect... Finally, your single motor is very light for a 25. Considering most folks are putting too much weight aft on their repowers, this is going to sound odd, but I think you may actually be running a little light on the stern. Some of these rigs were dressed with a pair of chevy 250 inlines. The chevy ballast concerns are quite valid, me thinks... Might consider setting 5 or 600lbs of sandbags centered in front of the motor and see if see runs a little more true to help define the problem.
