Old 01-26-2017, 11:09 PM
Welcome aboard Ken, and thanks for saving a Seafari, one of the more rare but most versatile of all SeaCraft models! Big is right, you have a '72 or earlier model, but my guess is that it's a '72 if you have the load capacity sticker under the helm. 73 and later models had the sticker below the helm. Mine is evidently an early '72, because it has the sticker on the port side of the cockpit, just aft of the cabin bulkhead and below the teak trimmed shelf.
Regarding the new synthetic core materials, check out surveyor Dave Pascoe's thoughts on the subject! There is little test data on the newer materials; he likes end grain balsa core because it has much higher shear strength than the foams, and unlike the foams which don't naturally absorb resin, it wicks resin into the grain, so it bonds very well to fiberglass!
When you're looking over the boat for damage, there is one area on a Seafari that should be checked. There is a small bulkhead just forward of the head location (forward of the hinged lid between the bunks. That bulkhead is tabbed to the inner stringers with some heavy (~24 oz) woven roving, and if the boat was run hard in rough seas, sometimes that tabbing will come loose.
Good luck with your restoration and post some pics, which tend to stimulate ideas and suggestions from this gang!
Old 01-30-2017, 12:54 PM
Sparehead Sparehead is offline
Thanks for the replies. I’ll add some pictures when I’m home later. I suppose this would be the place where a jewel in the rough can be appreciated. The Mrs. and mom-in-law were recently giving me crap for building a bracket to hold the stern that was “nicer than the boat” (their words).
So it sounds like I’m looking at a 72 at the latest. Whoops, I meant to write port side not starboard side regarding the capacity sticker. It’s located in exactly the same spot as Bushwacker’s, just aft of the cabin bulkhead. By the way, pictures of your nicely restored Seafari and many others on this site were instrumental in leading me to find my own Seacraft. The red boat is new to me but she’s a beauty too. Before I even looked at the boat I knew it couldn’t be an ’86 from reading the material on this site and the Moesly site.
I’ve already read a good deal of Mr. Pascoe’s material while scouring the web for information. I’m not yet set on deck material(s) and that’ll be a way off, but I’m pretty sure I’d like to use Coosa board for the transom, which should happen much sooner. I do still occasionally waffle on whether to use a bracket or keep it simple and just build a well around a motor hung on the transom.
It’s funny you mention that little bulkhead between the stringers in the cabin. As I recall from when I looked over the boat that was repaired once, poorly. If my memory is right it's currently a piece of plywood tabbed in with a single layer of woven roving. My plan is to remove the cap and deck and rebuild from the bottom up so in the grand scheme that will get sorted out. The stringers themselves looked undamaged throughout.
Old 01-30-2017, 07:06 PM
I thought I had more "before" pictures. I'll be sure to take some from each stage of the operation. That first picture was how I found it listed on Craigslist. The white stuff on the bottom in one pic is Citristrip loosening some iffy bottom paint. There were lots of old barnacle spots under that. I haven't done much more than strip all the old junk out and cover it. I meant to get the trailer out from under it before the snow but didn't get that far.
Old 01-30-2017, 11:48 PM
Originally Posted by Sparehead View Post
. . . I do still occasionally waffle on whether to use a bracket or keep it simple and just build a well around a motor hung on the transom.
You've done an impressive amount of homework! Nice bunch of pictures! You've saved yourself a lot of work by chemically stripping the bottom paint. I had mine soda blasted and it did so much damage to the gel coat that I ended up having to fill and fair the entire bottom! At least you have a nice cabin door and steering wheel hub which are missing on many Seafaris that are this old! Do you have the windshield for it? That opening windshield is a great feature that you can't find on modern boats! If you're missing the windshield, try using the search function, as I think some poor misguided soul on here recently posted about planning to butcher his Seafari to make a CC model the hard way, so he might have a windshield he doesn't want! That thru hull on the port side indicates that it had the galley seat at one time; so do you still have it or is it MIA? That seems to be a pretty rare option, but one that I've found to be very useful.
Regarding the bracket decision . . . I think that depends on how you plan to use the boat. If you plan to run offshore a lot in big seas, it is nice to have that solid transom, and that big swim platform is nice if you're a diver. However if you can find one of the full height splash well tubs Potter started making about '76 or so, it provides equivalent safety, and the boat is balanced much better and will ride better without the bracket. Modern motors are so much heavier than the 300 lbs the 20 was designed for, and a bracket + heavy motor seriously screws up the balance on the 20! Don Herman popped a mold off of one of those brackets, but was going to scrap it so forum member Rickg rescued it and took it over to our gathering at Terry England's place last September. I think Terry, brother-in-law Doug, or Vezo II now have it. A good shop could make a nice part using that mold!
Do you have soft spots in the cockpit sole or front deck? That whole inner liner is bonded to the top of the stringers with Potter putty, so it's not easy to remove! You have a 4-stringer hull, which I personally think is stiffer and stronger than the later 2-stringer design; those stringers are hollow fiberglass and never seem to have any problems, so there is no reason to remove the whole deck unless you think you have a bunch of wet foam under it. It would be MUCH easier to just cut off the top skin and replace the core than to pull out the whole inner liner or even the top cap for that matter. And I think you can get to that forward bulkhead through the front hatch under the bunks. I think it's pretty well bonded to the inner liner, but Potter made a mistake trying to tab it to the stringers with such heavy roving, which is so stiff it doesn't like to make sharp bends. . . a couple layers of 1708 laid down with epoxy would bond much better!
Old 01-31-2017, 09:42 AM
Doug returned Dons mold to me back in the fall and I now have it here in SC, where I have much better resources to pop the first one. Having assisted with building nine Jersey Speed Skiffs from a mold over ten years ago, I have to say that I have never seen a mold in better shape. Definitely a 10 out of 10. Impressive.
I'd love to see a photo of this part installed because looking at the mold is like looking at an old photograph negative. Plays with your mind. Only other option is to build one then try to convert the 1976 SeaCraft Seafari, the Blank Canvas, I still have in the yard from I/0 to outboard. I'd like to sell this hull.
Vezo, Part II
Old 01-31-2017, 12:50 PM
Here are some pics of the splash well tub, I believe from a forum member who loaned his part to Don to make the mold. Don does great work, so I can definitely believe that it's a first class mold!
Old 01-31-2017, 01:24 PM
Thanks Denny! Looks similar to the splashwell on my 79 MA! And sure does serve a purpose. Now I wonder if anyone has a mold for the upper shroud/rod/cup holders and bait station/cutting board. I have one from a 25' SeaVee but have not attempted to match it to the splashwell. Cool stuff.
I have the ability, resources and facility to fill transom of 76 Blank Canvas Seafari, cut and remove original I/O transom cap, build to 25" and a splashwell. Be a cool project but probably financially an overall loss. For now, I plan to compound original gel coat and see what is still there. Minimal crazing for her age, and may not require wet sanding. Even the dog house/engine box is in great shape. Just hate to part her out because she's a very strong candidate for a complete rebuild.
Regardless, I am so happy Don did not crush the mold in his dumpster, and I was fortunate enough to acquire it. (Thanks Rickg!)
Vezo, Part II
Old 01-31-2017, 01:56 PM
jtharmo jtharmo is offline
Vezo, Part II
A few months back I posted a photo of the splashwell tub removed from my late Seafari (link below). There is a little complexity on the lower surfaces that may look a little confusing on the mold. I thought this view may help visualize how it sits in the splashwell and along the inside of the transom. My Seafari had a 25" transom and there is no interference at all.
http://www.classicseacraft.com/commu...352#post245352
Old 01-31-2017, 02:22 PM
Awesome! Thank you SSPBill! This thing is going to be a gift in the long run I believe. The superstructure Don secured the mold to is very SOLID and will make for consistent part results! Thanks again Bill. How's the weather up there? Fox News has flurries outside!!! I'm originally from the Jersey Shore.
Vezo, Part II
Old 01-31-2017, 02:34 PM
After looking at BigShrimpin's Seafari, is it safe to assume Most were I/O's from the factory in 20, 23 and 25'? I wish GAbildgerat was closer.
