Old 02-07-2017, 08:11 AM
Billybob Billybob is offline
Default How much paint?
Hey guys, I'm spraying a 17 Mako with Awlcraft.
Have a gallon of the 545 primer but wondering how much we need for the colors.
Waterline to rubrail will be gray.
Cockpit/ console/deck will be white, but the non skid areas will be kiwigrip.
This stuff mixes 2:1.
I'm wondering if anyone here who has done an 18 or even a 20 could give me some guidance.
Don't want to buy more than we need, but certainly don't want to run out either.
Thanks
Old 02-07-2017, 01:57 PM
rcnight rcnight is offline
Just did my 20sf with Awlgrip. One quart of color/white should get you there. Have you thought about roll & tip? Can't beat the amount of masking and coverage you'll do for spraying. Just my 2cents. Good luck.
Old 02-07-2017, 02:21 PM
Thanks for the response.
The masking won't be too bad, and you can't roll Awlcraft anyway.
I'm doing this with my son's friend (who's also my fishing buddy) - it's his first boat so he's making the call on a lot of it, and he would not believe that a roll & tip could be as nice as a spray job - but I've seen some pretty impressive results.
Old 02-08-2017, 04:35 PM
AnthonyAllen72 AnthonyAllen72 is offline
How many coats would one quart get you? Rcnight
Old 02-08-2017, 06:49 PM
One quart will probably get you 4 coats with roll & tip. Don't forget you thin it out until its like water - so it goes a long way. If you go that route, you'll need to get the brushing thinner & activator. Speaking as a shade tree painter, I'll never spray another hull again. Leave the spray to the inside. You can get good results spraying the nonskid with the Awlgrip additives. I recently sprayed my 21' sailboat with one quart and got 3 coats. Do a search and you'll get plenty of advice.
