I rigged the engine and am running into issues with steering cable routing. The obvious solution would be to cut out some fiberglass to enlarge the rigging hole on the starboard side of the splashwell. To get it at the right level it looks like I'll have to cut right up to seat level. I don't see any way around it, so I think its time to pull out the sawzall and grinder.
@Mcgillicuddy: I think the weight of the engine is 369. It looks like they screwed and glued over the scuppers in the bottom of the hull(at least there is some sort of plate down there).
