Hello CSCers,
I am going over a 1974 23' Tsunami (Sceptre), 1-owner, I/O, and have found some unusual hull flex and moisture readings that don't appear on a similar boat I own. The moisture and flex is between the inboard and outboard strakes, and begins about 3 feet forward of the transom, increasing toward the bow. Is this a design feature (light construction)? Can anyone point to a cause for high moisture readings in the SC glass hull? The boat still rides fantastic. Thanks in advance |
How are you seeing the flex? What methods are you determining excessive moisture? I just went through my 74 Tsunami hull and the hull layup seemed unnecessarily heavy. I'm wondering if the hull you are looking at had been submerged or flooded for a duration of time.
[b]The Moose is Loose ! |
It sounds like where you are seeing moisture/flex is where the stringers are - if the foam in them is saturated with water it might explain the moisture readings but I don't have a clue about the flex. |
Typically.........flex / softness = deteriorated structure usually caused by the affect of water on wood over the long term.
30-50 year old boats.......regardless of brand were built with a lot of wood. Some were properly sealed with epoxy to last longer, some not and deteriorated faster. It is what it is. Be careful. |
I found the same thing accidentally (and repaired it) when I replaced my fuel tank. This partially has to do with the way the hulls/stringers were laid up and 40+ years of freezing and thawing cycles (some without a tarp/cover). I hope you don't have the same problem, but I'd be willing to bet this is the issue. It's easier to repair from the inside
![]() http://www.classicseacraft.com/commu...t=28644&page=5 ![]() |
Didn't even think about freeze/thaw busting the stringers loose. Makes sense.
Total sense. Us Florida folks know nothing of the hazards of freezing boats.
Thanks for everyone's comments. I agree busted stringers would be most likely behind the hull flex.
Going to investigate further. Think the boat may have grounded pretty hard once, maybe this created some cracking / openings for freeze/thaw damage. Opening it up this week. |
