Old 11-11-2017, 08:56 AM
pelican pelican is offline
first - solvent clean,scuff sand,solvent clean again - chemical etch prime,followed by either interprotect 2000 or coal tar epoxy,to the correct thickness...
setting tanks - starboard strips,these will work the best,setting the tank up,off any flat surface,allowing moisture under it to pass.
rubber,neoprene - these will actually trap water/moisture.
