Old 11-20-2017, 04:30 PM
Wooley Wooley is offline
Originally Posted by ssscotty View Post
i had a similar issue when i had the 74 sceptre, i took one side of a motor ear muff hooked up to the hose and put it over each deck drain thru from the underside of the boat... and sure enough one side allowed water entry. i ended up re doing them with a heavier duty compression fitting. problem solved.
Well I found I have a rotten transom . I’ll start there
