  #24
Old 02-14-2018, 10:03 PM
PackRat PackRat is offline
Thanks Rybones,
The hull was Aqua Mist and the topside was Insignia White.
On the deck, raised about 1.75 -2” . No issues with draining. I have not noticed a lot of water on the deck but a lot of use is back bay and generally protected water where might not show up. Just standing in the stern corner in calmer water doesnt produce any water - Im probably the heaviest in the boat so far at ~200 lbs. i purchased the rabud scuppers but opted not to install them as didnt see a need yet. Ill try to get a photo of the water line on the transom to show you how it sits with this motor, bracket, etc.
The Simrad unit was just installed with foam gasket and corner studs that came in the box.
I do have a 1/4” starboard panel accross the whole area that pushes it out a bit. It is a little snug to the front of the console but didnt feel it was a problem for connectors or cable bends. Seem to recall that the connectors were toward the lower half of the unit and the space goes up the lower you go due to the angle of the panel. Id send you a photo but I pull the electronics for the winter ..... I can send you a photo of the cut-out. Just used the provided template.
