Old 02-25-2018, 10:40 PM
If room allows some have taken a small Allen reach slipped it in the bad hole and turn it to clear out the bad wood then injected epoxy in the hole let it cure drill for the new screw and reset the anchor . Check to see if the old screw goes all the way thru as you might want to push in some kind of plug so the epoxy doesn’t just run thru
