Old 04-05-2018, 11:07 AM
Denny & Arden, all of us here at Area 442 could not be happier for the both
of you !!
What an amazing thing life is. One minute down, the next on top of the world.
One big question have we picked out a name for this ocean liner ?
Congrats and keep your SeaCraft family in the loop...
Old 04-08-2018, 09:32 PM
Thanks everyone for the kind replies! Yes, Ken the boat will be renamed “Dream Seeker”, because we’ll use it to pursue our dreams of exploring the country and living aboard! But we haven’t gotten around to that yet, as it’s very important to follow proper protocols, which involve specific formalities and significant quantities of alcoholic spirits, so as not to offend Neptune and Poseidon! Arden has also started a blog that we’ll update when we start cruising!
We’ve decided to delay starting the Great Loop till next year. We really should be leaving S. Florida in April to have optimum weather for most of the trip, and the boat just needs too much work to leave now. The boat is from Wisconsin and has spent most of it’s life in the Great Lakes! Although it has a Webasto diesel fired hot water heating system, it has no air conditioning! My friend/neighbor and buyers broker Jef found the boat in Stuart, said it had “good bones”, and thought that if we could buy it cheap enough to install air conditioning, it would be a good value. The previous owner had it in the Bahamas when he had a stroke! Poor guy is only 65, but he’s paralyzed on one side and can’t speak, so they had to fly him to Florida, hire a captain to bring boat back and his wife just wanted the boat gone ASAP! It was out of the water for bottom paint when we saw it and made an offer on it. We negotiated with the owner to have an additional thru hull and sea cock installed at my expense for the AC pump, since that would save ~$800 for another haul out that I’d have to do if I waited until after I owned it! I think that worked in my favor because when we later discovered that all 8 batteries AND the 8KW generator were shot, the owner had new batteries AND a new 9KW Cummins/Onan genset installed because they realized I was a serious buyer!
We moved the boat to NPB to Jef’s house where he is overseeing the installation of 4 AC units in the 2 cabins, pilothouse and salon/galley, which should finish next week. Before the move I had the exhaust elbow on the port engine replaced, as it had overheated at full power during the sea trial. That fixed the problem, since the original 32 year old exhaust elbow was rusted internally and restricting cooling flow thru the heat exchanger. During the trip south, we noticed the Stbd engine was rough at idle and it stalled several times when we put it in gear. The engine surveyor said that indicates a problem with the high pressure injection pump, because it’s a governor-type control that is supposed to hold rpm when load is increased, so I pulled that pump and all the injectors last week to have them rebuilt/cleaned. We need to top off the fuel and water tanks and repeat the sea trial to see if the engines will make any more power with clean injectors, as the engines would only turn 2400 rpm. (They should turn 2800 @ WOT) If we need to reduce pitch, those 4 blade 26” diameter props won’t be cheap!
I’m on the waiting list for a slip at 2 different marinas in Stuart and will try to move it up there as soon as we get the engines squared away. Will also try to bring it to the SeaCraft gathering in Jensen Beach if possible! Have attached a few more pics of the boat after we launched it and did the sea trial. Last pic is from sea trial at WOT in the St. Lucie river, at about 11 kts. At 8 kts, it doesn’t leave much wake!
Old 04-08-2018, 10:48 PM
Ed Ed is offline
Denny-
Congrats on your new boat and the adventure that awaits you.
What marina in Stuart are you on the wait list for? If you are open to it, there is a great, quiet and well protected marina in Hobe Sound called Loblolly. It is right off Peck Lake.
It is extremely safe and no bullshit to deal with.
Anyway - where ever you wind up I am sure you will have fun. Enjoy.
Old 04-09-2018, 05:51 AM
Ed, thanks for the tip on the Loblolly marina! I know where that is so we’ll check it out! North Palm Beach is a 40 minute drive from Palm City but Hope Sound is only about 15 minutes away and a little easier to get to than fighting traffic in downtown Stuart! Slips are very scarce in this area, but temps here are now in the low 80’s and the snowbirds are starting to leave, so maybe something will open up!
We’ve talked to the Harbor Inn & Marina, a small marina on the N. Fork of the St. Lucie where Arden’s late husband used to keep a sailboat. They’re working to raise a couple of sunken sailboats from the last hurricane which are blocking several slips. The other is a Loggerhead marina, just NE of the Roosevelt Bridge over the St. Lucie. It’s a 300 slip marina with over 200 slips that were wiped out by the hurricane that they’re working to restore. It’s a nice marina with floating docks and tall pillings; although it’s fairly exposed to fetch from the E and SE, it does have a low breakwater so it shouldn’t be any worse than marinas on the N. Fork that have no protection from small boat wakes. Loblolly should have neither of those problems!
Old 04-09-2018, 12:05 PM
Wow, sounds like great progress! Hope to see it and y'all at the June 1-3rd East Coast Gathering.
Old 04-09-2018, 02:06 PM
How are you Denny? Sorry I missed meeting Arden last fall so close to home but Irma was rough on me. So happy for you! So you sold your house and now live in Palm City? I have very close friends there, since childhood in NJ. Hope to see you for a cocktail when I make it over, because I will not be attending Jensen since the date change. I will be boatless at the Sportsman after a great invite from Ken and Mel, Mother’s Day is a very special day for me. Very happy for you buddy!!!
BTW, I have been using the Seafari a little over the last week but I believe that the throttle cable was the culprit of extreme sudden response. Have not installed four blade Power Tech yet. Also, have decided to invest in the ‘79 MA, certifying her Garage Queen title.
Best of Luck, and keep in touch...
Michael.
Old 04-09-2018, 04:10 PM
Ed Ed is offline
Denny-
The marina & mooring field near the Roosevelt Bridge is it called Sunset Bay? I think that used to be owned by the city, no? The guy that bought it around 2009 or so dumped a ton of money into it (his son used to work for me in Boston). We used to pass it on the way to American Custom Yachts for our annual haul out. It is also pretty close to Capt Chuck's house!
Anyway - you will love Loblolly. It is a private club with lots of beautiful homes. Very secure - they have full time security. The marina is mostly private but they lease out a handful of slips to select individuals from the public. The best part is...Peck Lake is great for dinghy rides and for exploring Jupiter Island. Ray Reganato was the dockmaster when I was there about 6 years ago. Tell him Ed says hi. They were not full when I was there...but the economy has changed significantly since then.
Old 04-11-2018, 10:27 AM
Ed - Still trying to make contact with Loblolly but will keep trying. Thanks again for the tip! Sunset Bay is on the West side of the Roosevelt, basically across the road/bridge from what is now called Loggerhead Marina. The latter has a bunch of Fleming boats that may be moving in another month or two after their dealership completes their own marina.
Loggerhead also suggested contacting Nettles Island Marina in Jensen Beach, which got totally wiped out in Irma, so will try them but not optimistic! For a storm that didn’t seem to get all that much press coverage, Irma really did a number on the whole state of Florida!
Old 04-11-2018, 10:38 AM
Ed Ed is offline
Hi Denny-
I just sent you a pm with the cellphone number of the dockmaster at Loblolly. Good luck.
Ed
Old 05-13-2018, 10:26 AM
Wow, Denny, that's quite a switch from the 36 Helmsman you had mentioned !!! Beautiful boat, and you're right, they get smaller the more time you spend on them ! Big Congrats to you and Arden !!!
